bosch sgs095au/11 dishwasher
Home Forums Public Support Forums International Forums Australasian Appliance Forum bosch sgs095au/11 dishwasher
  • #39453
    mike1
    Got trouble with this dishwasher,top of the range with a pcb on facia and main pcb down the r.h.s. Its not drying correctly and display gets stuck on “1 min to end”.Heats o.k. on wash,drains o.k., tube at bottom not blocked,any ideas?.
    kind regards
    mike
    #262471
    Re: bosch sgs095au/11 dishwasher
    You might want to check that number, Mike. Can’t find anything relating to an SGS095.
    mike1
    yes sorry, i have missed out a zero the model no. is sgs0905au/11.
    mike
    #262473
    Heat, has to be to do with heat. There is only one heater and the dry cycle works on residual heat from the last (hot) rinse.
    Horribly complex machine – underfilling is an issue which affects heating quite seriously. The computer will default to the “1 minute” to indicate a problem.
    I’ll go and poke Gegsy – he has rather more in-depth knowledge than I do.
    Do tell – why is an Oz spec machine in Staffordshire?
