BOSCH SGS09L12GB
  • #23317
    jota
    Hello Gents and Ladies 🙂
    I have a problem with this machine that keeps changing washing times and after just does part of the program checked timer (changed) went well for a while now is getting the same sintoms is there anything that i miss out?
    Any help would be appreciated.
    Thank’s
    #197730
    Moved to Trade Tech.
    Re: BOSH SGS09L12GB
    jota wrote:checked timer (changed) went well for a while now is getting the same sintoms is there anything that i miss out?
    It will be a fault with the turbidity sensor I expect? When you say you’ve changed the “timer” do you mean the main power module in the base? Is the heater working I wonder?
    #197732
    nationalhomecare
    Re: BOSCH SGS09L12GB
    Could be problem with pressure chamber/transfer hose too on this one as has metering tank on left hand side and does the usual 1min remaining thing and time altering as insufficiant water to operate diaphram on heater box 💡
    Could be open circuit heater element too.
    Never had to change a pcb on this one, is located in base at right side in front of heater terminals, nice reliable AKO one if my memory serves me correct??
    I think i seen a link on here somewhere about the 1 min thing???
    Good luck! 🙂
    nationalhomecare
