Hi Folks.
My Dishwasher works just fine but latley has been keeping me up during the night. The problem is that it will turn the water inlet valve on and off about 20 times during the fill cycle, this in turn makes the plumbing knock.
I have checked the electrical supply to the inlet valve and found that it is in fact being turned off and then back on during the fill.
I can’t recall this ever happening in the past. Could this be a fault with the water level sensor, or is this a normal fill cycle. 😕
It’s usually due to the transfer pipe between the fill matrix to the tub that gets crudded up and needs cleaning! 😉
Little tip…..never go to bed leaving things like dishwashers working. When you hit the sack and turn out the lights, turn off your gadgets as well. 😉
