Bosch SGS3042GB Problem
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS3042GB Problem
  • #64866
    moreton
    I’ve had my Bosch dishwasher for about 8 years and it ran three quarters of the way through the normal cycle (to steam/dry) and then the fuse blew with a bang. I tried it again the next day and it started normally by pumping water and then when it reached the quarter cycle stage (water heating I pressume) it blew again with a bang. I suspect it might be the heating element but would appreciate any tips? Many thanks
    #358334
    gandh1
    Re: Bosch SGS3042GB Problem
    did the plug fuse blow or is it the fusebox rcd tripping?
    #358335
    moreton
    It is the fusebox rcd that trips…
    #358336
    clicon357
    Take a look at my thread on this exact model that’s 10 years old and that I’ve recently had problems with. All cleaned up and running like new!
    viewtopic.php?f=33&t=64526
    IMO would say that it’s your heating element in the “instantaneous water heater” that’s playing up. Sounds grander than it actually is – I replaced just the element. The element gets 230v to it pretty much as soon as you switch on. What’s happening with yours is as it heats up it expands a little and shorts out tripping everything. Next time it starts off “cool”, heats up and goes again. Reckon you will find that soon it won’t heat up at all. Anyway read my thread and any problems just ask. New element and a good clean is probably all it needs.
    Cheers
    #358337
    moreton
    Thank you so much for taking the time to help. I’ll try a new element and a good clean and let you know how it goes. Thanks again, I am most grateful!
    #358338
    gandh1
    heater elements arent cheap and only available as a complete unit. in order to retain watertightness, you need to unscrew from the sump base to fit. dont be tempted to unclip them from the side of the holder…
    ask KWATT for part 264512 but they arent cheap so worth checking that the element is at fault first. earth trip faults on a bosch could be chewed wires, for some reason mice seem to like the insides of bosch and neffs ALOT. could also be leaking onto electrics.
    #358339
    clicon357
    I got just the element. Fitted it and all working like new – no leaks either. It was a bit of fiddly holding all 4 plastic clips off that hold the element in but I’d do it again no problem. UK Whitegoods do the “whole unit” here:
    http://shop.ukwhitegoods.co.uk/Dishwash … eater.html
    #358340
    gandh1
    Clicon, please make sure your information is accurate in the public forum. That might be the correct part for your machine but it is not the listed part for the OPs (original posters) dishwasher. You may very well find that the element is the same inside but there are other parts fitted to the whole unit that will not be. these may then cause danger and/or expensive and irrepairable damage to the electronics. As mentioned previously, they are supplied as a “whole unit” for a reason. by unclipping them and refitting the element not only do you run the risk of a leak, you may as well fit the new ntc and diverter motor *if fitted* as the diverter motors have been known to fail and take out the electronics.
    Please also remember just because you have solved your problem sucessfully, it does not always mean it is the only solution. £70 for an element is a lot of money to spend if its not actually faulty, or if its damaged the electronics too. hence my advice to get it checked out first. its very likely it is the element but speaking as an engineer i wouldnt order one in just on hte hunch it had failed.
    moreton it would help if you have a friend who is an electrician to do an insulation test on the element in return for a couple of beers, and as previously stated, if you feel confident enough, visually check the pcb for damage too, before ordering parts.
    #358341
    clicon357
    Clicon, please make sure your information is accurate in the public forum. That might be the correct part for your machine but it is not the listed part for the OPs (original posters) dishwasher. Erm…..yes I think you’ll find it is. The OP’s model is a SGS3042GB/03 just like mine and the link takes you to the instantaneous water heater for that model. Furthermore the part you quoted him 264512 only fits SGS3042GB/01. Please, correct me if I’m wrong.You may very well find that the element is the same inside but there are other parts fitted to the whole unit that will not be. these may then cause danger and/or expensive and irrepairable damage to the electronics. As mentioned previously, they are supplied as a “whole unit” for a reason. by unclipping them and refitting the element not only do you run the risk of a leak, you may as well fit the new ntc and diverter motor *if fitted* as the diverter motors have been known to fail and take out the electronics.
