Bosch SGS3062GB/02 not draining
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS3062GB/02 not draining
  • #52289
    naomiconnon
    My dishwasher has stopped draining, I have cleared the filter, taken it out and cleaned underneath it, I have also taken the side off and checked the pipes are not blocked, how can I get to the pump to see if that is blocked or could it be another problem? Any advice would be gratefully recieved.
    #311222
    Re: Bosch SGS3062GB/02 not draining
    Bail out as much water as you can. There is an access panel in the left hand side of the floor of the sump. Remove the screw and lift the panel away to get to the pump impellor.
    naomiconnon
    Thanks, I have done that and there insn’t anything blocking it. Could it be anything else?
    #311224
    nomadPaul
    What happens when you reset it ? Does the pump run or just buzz ? If it runs but doesn’t drain , its a blockage somewhere. If it just buzzes and doesn’t spin then the chances are the drainpump is faulty.
    Have you checked the drain hose connection spigot….especially if its connected directly to your sink outlet ?
    #311225
    naomiconnon
    It sounds like it’s running, the water is covering the impellor and when I run it, the water is being sucked down but not being pumped out, could something have got passed the impellor and blocked the pump?
    I’ve checked the pipes and they are all clear.
    #311226
    nomadPaul
    If you’ve taken the access cover off the pump , don’t forget it needs to go back on for it to drain properly !
    #311227
    naomiconnon
    Hmmmmmm, ok thanks 😳
    #311228
    naomiconnon
    A big thank you, I have put the cover back on and run it and it appears to working perfectly 😀
    #311229
    alexuk
    This has been very useful to me too! Just fixed mine in the same way!
    #311230
    DarkWater
    Does anybody know the specifications of the screw that was removed in the earlier step – I removed mine to clean out debris, and I misplaced it?
