Bosch SGS4012GB/07
  • #5045
    ChrisR
    Hi guys & gals. 😀
    Happy New Year.
    On the above dishwasher,how easy is it to change the water softner?. 😥
    Thanks. Chris.
    #108424
    ChrisR
    Re: Bosch SGS4012GB/07
    The water softner is leaking from the top of the sealed chamber.
    #108425
    nemo
    you sure its not just the nut loose?
    if not turn it upside down is easier
    #108426
    Kentish
    Probably the nut just needs titghtening, but easy to get at the softenor.
    I find removal of lid and side panels first, followed by the lower front shaped panel, pull the spring mounts out of the base points, remove the front base fixing screws (I assume you have remove the rears when you took the side panels off) .Then unclip the wiring harness guide, then pull the base away, but carefully and not too much either.
    Softenor is there and accesible.
    When playing with these dishwashers, just remember most of the goodies inside use the base for fixing or holding in place, and pay special attention to the float switch by the softenor as it breaks real easy.
    One last thing, I always do it on their backs having put it like that once lid, side panels and rear base fixing are off.
    Kentish
    #108427
    Turn it upside down! you gotta be joking!
    #108428
    sparkey
    Are you sure water softener is at fault, its not unkown for pin holes to appear in stainless steel causing water to drip onto top of softener.
    BSH Appliance Care have special low temperature solder available to seal leaks
    #108429
    Dave_Conway
    sparkey wrote:BSH Appliance Care have special low temperature solder available to seal leaks
    They do ? 😯
    Sparkey, any idea of the part number please 😀
    Thanks.
    #108430
    ChrisR
    Thanks guys for your help on this one and thanks a lot Kentish for your step by step guide.
    sparkey
    Sorry I don’t think there is a part number, their technical department will send a short piece long enough to do a couple of repairs.
    As you would expect they do know how to charge.
    It does the job ok without any dismantling so it’s worth it
    #108432
    Kentish
    eastlmark wrote:Turn it upside down! you gotta be joking!
    Thats why I siad on its back….not lid.
