Bosch sgs4012gb/13
  • #88000
    1totalshambles
    Hi everyone.Hope someone can help, maybe Martin can help me with this one rather than taking the p*ss.
    This weeks disaster is a bit of a weirdy one. Bosch dishwasher with electromechanical timer and this is the problem: will not pump out on any pump out click, the timer just clicks on through each and every pump out position. If you remove the l/h/s side cover and raise the red rod to simulate a base flood the pump will work just fine and pump out the water, so the pump is not the part that is faulty and neither is the o/flow m/swt.
    It fills normally to a normal level, no crud what so ever in p/swt or fill chamber or sump hose, the machine heats up, meggered heater which is 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} fine, probably over heats on the 85 degree stat but that`s probably due to not pumping out and sailing through the programmes on to the next heat cycle rather than a zapped thermostat. Cannot see any internal wiring loom wire problems, connector block near heater is fine, no leaks. Everything works it just will not pump out on any pump out click.
    Bit stuck, Any ideas please? Programmer fault perhaps but that would surprise me. Anyone else ever have had this problem?
    #436711
    Re: Bosch sgs4012gb/13
    Timer control unit faulty?
    I think I asked you before, but can’t recall whether you’re in the trade or not? Or just a dabbler in domestics?
    #436712
    1totalshambles
    Update. Yes it was the programmer at fault. Now replaced and works fine.
    As far as appliance repair goes I`m semi retired Martin.
