Hi all,
We have a Bosch SGS4012GB/13 dishwasher which has been excellent for around 10 years but now has a problem.
We put the dishwasher on a couple of nights ago and found it still running in the morning! I opened the door and cound see it was still in the wash cycle, (the water was hot). The program had advanced to between settings 3 and 4 with the dial pointing to just before the vertical position. I manually advanced it by one click then it continued through to after position 4 and then needed a further one click advance.
I cleaned out the water matrix, the float at the top was jammed with crud. I’ve also cleaned the pipe which goes into the pump, that had blocked on a previous occasion. Tried it again and got the same symptoms. 😥
Any ideas on how to fix this?
Thanks for any advice.
