Bosch SGS4012GB – water inlet hose..does it need a washer
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS4012GB – water inlet hose..does it need a washer
  • #29593
    museumsteve
    Maybe a silly question, my DW wasn’t taking water in and found the base was, this of course activated the float switch. I found that the water inlet (at the rear of the DW where my water mains goes into the machine) was leaking. I took the hose off and there is no rubber seal/washer, should there be one or is it a simple flush fit?
    I got the machine off a friend after mine died so he took it out from his house so not sure if there was a washer/seal to begin with.
    Thanks in advance..and have to say this is a fantastic forum. I also just fitted a new door seal which I probably wouldn’t have done prior to visiting here 🙂
    #223751
    Simon46
    Re: Bosch SGS4012GB – water inlet hose..does it need a washe
    Yes washer required to seal.
    Regards
    Simon
    #223752
    Yes it should be sealed with a black rubber washer. 😉
    #223753
    museumsteve
    Thanks chaps..guess a trip to B&Q this morning then 🙂
