Bosch SGS4332GB dead
  • #14392
    Trav
    Machine ( 3 years old ), appears to be dead – no LED’s lighting up.
    There is power to the main switch, and the door lock is working.
    Any ideas on how to proceed would be appreciated.
    #159272
    Del
    Re: Bosch SGS4332GB dead
    First thing I have to say is power off at all times.
    That said if you have totally convinced yourself that power is passing through the door switch then the most probable cause would be a faulty electronic control module.
    Trouble is that should you order up and try to fit one and it doesn’t work for what ever reason, then you have wasted a lot of money as they are invariably expensive and non returnable.
    Therefore I would strongley suggest that you call in an expert as parts fitted by a reputable repair firm will come with a guarantee. Plus the fact that if they should inadvertantly happen to order the wrong part it is then their problem, not yours.
    You can contact a reputable repairer in your area by clicking on the Repairs@ module on the lower left hand side of this page.
    HTH
    Del
