Bosch SGS43A12BG/27 Machine ha stopped with water remaining in it. There are no lights on the panel and it will not start. The mains supply is on and power is getting to the start switch, but nothing happens when it is pressed. Help please. Harhum
Your machine is subject to the major safety recall that has been all over the press and TV of late. Do please check HERE to see if your machine is included in this FREE repair recall. 😀
Thank you Martin for your valuable advice. My machine is one of the recall batch and I have contacted Bosch to arrange an engineer’s visit. I told the call centre that I had a problem, but the engineer will come anyway.
With any luck the recall component might be causing my problem.
Thanks again.
Harhum
