BOSCH SGS43A12GB/42 Program times way out.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries BOSCH SGS43A12GB/42 Program times way out.
  • #22241
    whiskeyjack6058
    So I have the above Dishwasher which I attended a service call a week or so back. Customer told me that It wasn’t heating up, so I did the usual checks and diagnosed it with a faulty module. Customer ordered the PCB direct from BSH Appliance Care as Connect distribution had no stock. I was called back to fit the PCB and to my relief my diagnosis was correct as we now have heat in the cycle. However, we have a quick wash program that displays 138mins which should be aprox 30′. There is a conversion which comes with this PCB but I didn’t think I needed to use it as it’s a like for like fit, but perhaps the PCB may need setting up. The information that comes with this suggests that: “incase of an equivalent controll the wire at the module (terminal clamp 5) of appliances up to KI12 must be cut through and be fitted to the enclosed double terminal at the wire (terminal clamp 7).”
    Then follows another Procedure:
    “After the modification the special circulating pump controll (sicasym) of appliances up to Ki12 must be switched off as follows:
    G-controll, with 7-segment display
    S4 + S5 must be pushed and kept pushed down and the appliance must be switched on with HS.
    Display1 = with Sicasym
    Display0 = without Sicasym
    Change over with S4
    Store with HS off
    Then there is another procedure for what would appear to be a different type of PCB without 7 segment display.
    There is an illustration that indicates S4 & S5 as the switch buttons on the pcb, there is nothing to explain what ‘HS’ is…..
    Im lothed to start cutting into the wiring loom to fit this connector as it really doesn’t make any sence to me, and with 17 years experience repairing domestic appliances without many problems I have to say i’m between a rock and a hard place on this one!!!
    Any Ideas Chaps?
    Thank you!
    #194156
    superfix
    Re: BOSCH SGS43A12/42 Program times way out.
    The times have nothing to do with the cutting into the wiring and fitting the connector.
    It’s all to do with the CODING for the module.
    There should be a seperate sheet in the box telling you how to do it.
    #194157
    whiskeyjack6058
    Thank you for that Boro, The onle seperate sheet I have is a duplicate of the other one in a different language, nothing else.
    #194158
    superfix
    I’m sure if you have a word with Gegsy he’ll be able to e-mail you a copy of the coding instructions 😉 .
    Unfortunately I never keep them.
    #194159
    gegsy
    Whiskey check your email and hi Boro 😀
    superfix
    Re: BOSCH SGS43A12GB/42 Program times way out.
    :waving:
    #194161
    gegsy
    Stu
    :waving:
    #194162
    whiskeyjack6058
    Thats Fantastic Gegsy, Thanks very much!
    #194163
    roy1
    Some bosch dishwashers set the program time
    based on the previous wash cycle on that setting
    or factory test then adjust it when the program
    is running.
    Roy
