Bosch sgs43a18gb/27 dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch sgs43a18gb/27 dishwasher
  • #41322
    dena89
    Fitted new timer to this, for a no heat fault.
    It now heats, but none of the programs have
    correct timings or temperature. Also it seems you
    can select 2 or more programs at the same time.
    Auto wash appears not to work.
    I am aware that this timer learns duration as it
    goes along. been fitted now for about 3 weeks.
    Any boffins out there cured this one?
    thanks in advance.
    #269543
    lerch
    Re: Bosch sgs43a18gb/27 dishwasher
    Did you set the timer for the correct model as some pcb’s work on several machines ???
    #269544
    dena89
    cheers lurch.
    there was no chart to do that, but fitted
    another one several days later that did have. So went
    back and tried it. Press all four buttons etc etc.
    wouldnt do a thing.
    #269545
    lerch
    Did you fit bosch part number 482935 which then changes to 489607 ???
    #269546
    dena89
    will have to check that. bought from wholesaler after quoting model number.
    #269547
    clivejameson
    I’ve had one recently where the pcb was supplied without the programming sheet which wouldn’t program correctly. Once I had the sheet I coded it for the model and all was well.
    Did you code it with the fascia on by any chance?….the buttons on the pcb S1, S2, S3 etc don’t tally with the buttons on the fascia 😉
    #269548
    dena89
    The timer i got for this model had no coding sheet,
    except for setting it for “sicocet” or something, which
    was advised on here not to bother with. To do with air in the inlet chamber
    believe. Later fitted another timer to a different model, which had coding
    sheet. I tried that and doesnt do anything. according to it, holding buttons
    s2,s3,s4,s5 and turning on, causes lights to flash, which they dont.
    Beginning to think maybe its just a duff timer.
    Entire job has been a pain as first tried emw repair which didnt work!
    customer is very patient, but defo not made any money on this one.
    Anyone with coding sheet for above model please help, last try b4
    orders yet another timer.
    Pity it not made by Indesit, at least then be used to it being rubbish!
    Ah well has to smile………….
    #269549
    clivejameson
    Let me know your email addy 😉
    #269550
    dena89 wrote: I tried that and doesnt do anything. according to it, holding buttons
    It’s important to press the 4 end buttons without it being fitted into the console panel. I suspect you may not be pressing S5 at all? S5 is hidden and unused whilst in position on this model. 😉
