Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch SGS43A22GB/01 Dishwasher overfill
- This topic has 12 replies, 4 voices, and was last updated 21 years ago by
Simon46.
April 7, 2005 at 9:36 pm #8898
Simon46
ParticipantBeen to above tonight. Fills till the mushroom in the middle of the cabinet lifts and drains. Checked the float with the magnet moves up and down and is magnetic (no pressure switch)and turned it round just in case. only 18 months old and fault occurs intermittently as per customer. Any ideas?. Is it likely to be board?
SimonApril 7, 2005 at 10:00 pm #130994Simon46
ParticipantRe: Bosch SGS43A22GB/01 Dishwasher overfill
ps have read Eastlmarks post http://www.ukwhitegoods.co.uk/modules.p … 43a22gb+01
April 7, 2005 at 11:19 pm #130995BSH-MAN
What is the FD number?
April 7, 2005 at 11:33 pm #130996gegsy
Simon46 wrote:Been to above tonight. Fills till the mushroom in the middle of the cabinet lifts and drains. Checked the float with the magnet moves up and down and is magnetic (no pressure switch)and turned it round just in case. only 18 months old and fault occurs intermittently as per customer. Any ideas?. Is it likely to be board?
SimonIf you have turned float around, put it back to the light coloured part upwards.
I have found module to be at fault mostly with the overfill, along with the magnet chaffing on crud.Greg
April 7, 2005 at 11:50 pm #130997Simon46
FD nr is 8206 BSH man.
S.
April 7, 2005 at 11:53 pm #130998Simon46
Thanks Greg that was my next question.
S.
April 8, 2005 at 1:05 pm #130999BSH-MAN
If the FD is before 8211 (IIRC) then a new module and mushroom float sould be fitted.
The new module will “time out” on the fill and thus avoid any embarrassing leaks. 😳
For the record, the factory says the reed switch float should be grey side up. 😉April 8, 2005 at 5:40 pm #131000Simon46
Thanks BSH man. You are a credit to this site. Does the whole assembly have to be fitted or can the mushroom just be changed?
Cheers
SimonApril 8, 2005 at 8:35 pm #131001superfix
replace both pcb and mushroom together to get job right.
new logic on pcb is timed fill for wash instead of relying on reed s/w
April 8, 2005 at 8:42 pm #131002gegsy
BSH-MAN wrote:For the record, the factory says the reed switch float should be grey side up. 😉
Sorry grey side up; cleaned enough of them 😳
April 10, 2005 at 7:41 am #131003Simon46
Similar to the E2 thread on the bosch fridge freezer two module parts are listed on the BSH website. 488155 and 489492(subst). Which is the one to order?
Regards
S.April 10, 2005 at 9:52 am #131004gegsy
Simon46 wrote:Similar to the E2 thread on the bosch fridge freezer two module parts are listed on the BSH website. 488155 and 489492(subst). Which is the one to order?
Regards
S.Hi
ALWAYS order the substituted part, as this will be a modified/upgraded spareGreg
April 12, 2005 at 7:39 am #131005Simon46
Thanks Greg.
S.
