Bosch SGS43A32GB/01
  • #60077
    rocker
    this machine is overfilling, it has a float system that activates a reed switch..will this unit cause this problem !!have workked on one a while ago and remember taking out float and cleaning !! cant remember the fault though.
    john
    #340659
    Re: Bosch SGS43A32GB/01
    Magnetic float under filter in tub needs cleaning. Failing that it’s a new Module AND float required (modification).
    #340660
    rocker
    Thanks for reply martin, when you say module do you mean the electronic timer module.
    #340661
    Yes. So if it isn’t the magnetic float causing the prob it may need a new module to sort, that then can get costly. 🙁
    #340662
    rocker
    Thanks very much for your fast reply & tec help Martin.
    John
