Bosch SGS43A32GB/01 (D/W)
  • #28838
    rocker
    This dishwasher has a fixed side tank, also no Air pressure system, it is overfilling, and has an internal anti flood system. but unable to know were to start to look as everything appears to be sealed, never worked on this type before..
    can anyone please help.
    Cheers John.
    #220284
    clivejameson
    Re: Bosch SGS43A32GB/01 (D/W)
    A good place to start would be the float….situated at about 6 o’clock in the sump under a pull-off cover…often get bunged up and stuck. Make sure there is no condensation in the clear part of the float (new float req’d) and that you put it back the same way up 😉
    Any doubts about it then renew it anyway….part no. 188106
    HTH?
    #220285
    Redflame
    If it’s a pre 2004 model make sure the cut-outs on the “Mushroom” antiflood mechanism is approx 2mm – If they are larger (5mm) then you will need to also replace this as well as the module (which now does a timed fill so does not rely on the floats) – I can’t remember the part numbers unfortunately. Also as “Clivejameson” said check the float & clean as they have a habit of attracting Iron filings from the water !
    Hope this helps.
    #220286
    rocker
    Thanks to both of you for your help, will be looking into what you both have advised me. John.
