Bosch SGS43A32GB/04
  • #34193
    DanDann
    Help,This dishwasher keeps overfilling,but i cant find any system to switch water of,no pressure switch or microswitch system-anybody got any suggestions..????,,Andy
    #241611
    gegsy
    Re: Bosch SGS43A32GB/04
    If you take the filters out and look at the 6 oclock position, there should be a round cover which you remove, then inside the opening there will be a float. Remove the float noting which way round it came out 😉
    Clean it and its housing as they tend to chaff and not float smoothly thus sensing water level incorrectly.
    If you post the FD up, some of these af certain date IIRC needed a module and safety sensing unit change (mushroom unit in base)
    kelland
    these had a modification after a few months of being out, the module was replaced and had a built in time-out on fill, if you remove the float/magnet in the sump DONT put it back in upside down!
