Bosch SGS43A42GB/01
Viewing 6 posts - 16 through 21 (of 21 total)
  • #153794
    gegsy
    Re: Bosch SGS43A42GB/01
    BSH-MAN probably means the water sensor fitted on some Excell w/m to sense when water enetring machine at an acceptable frequency.
    Situated above dispenser inline with internal hoses from fill valve.
    superfix
    gegsy wrote:BSH-MAN probably means the water sensor fitted on some Excell w/m to sense when water enetring machine at an acceptable frequency.
    The latest dishwashers also have them now Greg. They are fitted in line between the inlet valve and side chamber.
    #153796
    bobokines
    That was my thought, does BSH-MAN’s post refer to a washing machine?
    Bob
    #153797
    gegsy
    Penguin45 wrote:Er, plates don’t generally soak up water…….. πŸ˜€
    Paper plates πŸ˜‰
    gegsy wrote:
    Paper plates
    In a dishwasher? You tight git…….. πŸ˜€
    BSH-MAN
    bobokines wrote:That was my thought, does BSH-MAN’s post refer to a washing machine?
    Bob
    Sorry if I caused any confusion. The dishwasher that started this thread does not have a flow sensor.
    But the model now supersedes to one that does. 8)
    My post was intended to be a β€œheads up” about the fill system you independent guys who will be seeing these types soon, as they come out of warranty. πŸ˜‰
    I used the washing machine (that still uses a pressure switch for level) flow sensor as a term of reference.
    This flow sensor was only fitted to top end washing machines, so not seen in big numbers.
    πŸ™‚
