Bosch SGS43A42GB/01
Viewing 15 posts - 1 through 15 (of 21 total)
  • #13253
    ChrisR
    Hi guys.
    How does this dishwasher determine water level?.
    I`ve got one that overfills and sets off the anti-flood but I can`t see how it gauges the level.
    Thanks.
    Re: Bosch SGS43A42GB/01
    Try this thread chris:
    http://www.ukwhitegoods.co.uk/modules.p … ishwashers
    #153781
    Edit required there, Mark…….. 😀
    I know, i am still looking for the correct thread having just posted an incorrect one.
    #153783
    This one?
    http://www.ukwhitegoods.co.uk/modules.p … pic&t=9007
    gegsy
    To go off topic a tad, Bosch suggest changing PCB and float assembly to combat this fault.
    ChrisR
    Thanks Gentlemen, for your kind assistance 😀 .
    #153786
    roly16
    Appliance Care will do this job foc even if the machine is out of g’tee.
    geoff
    #153787
    BSH-MAN
    Some of the very latest types use a flow sensor, much like ones fitted to the washers.
    Oh, and they do sometimes fail.
    :lesson:
    #153788
    bobokines
    How does a flow sensor actually work. Does it have a rotating impellor and actually measure the quantity of water passing?
    Bob
    #153789
    Dave_Conway
    Pretty much Bob yes.
    They are similar to motor tacho’s and generate a frequency as water passes and spins a rotor.
    #153790
    Dave_Conway wrote:generate a frequency as water passes and spins a rotor.
    I think Bosch call them ‘Impellor Jugs’ for some reason?
    #153791
    BSH-MAN
    Yes, literal translation I think. 😀
    #153792
    bobokines
    BSH-MAN wrote:Some of the very latest types use a flow sensor, much like ones fitted to the washers.
    I have never seen a washer with a flow meter? 😕 Where would it be situated and how do they sense the water level when the clothes soak up the water?
    Bob
    #153793
    Er, plates don’t generally soak up water…….. 😀
