Bosch SGS43A52GB/04 dishwasher.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGS43A52GB/04 dishwasher.
  • #37281
    aqualectric
    Bosch SGS43A52GB/04 dishwasher. FD8207.
    There is no supply to the top rotor and low pressure at the lower rotor. I suspect the “distribution valve” (motor driven disc controlling flow on heater box). I took the rotor supports off and looked down into the pipes from the heater and one is shut off by the white disc. I have tried the machine several times but the disc does not seem to move at all.
    Anyone else had this fault? Can the clock type motor be changed without replacing the whole heater assembly?
    Help please!!
    Steve.
    #254238
    Re: Bosch SGS43A52GB/04 dishwasher.
    Heater box complete, Steve – 483257. The motor is the same as the Indesit W series selector switch motor, but Gegsy reckons the things are more prone to the gears jamming than the motor failing.
    You’re going to have to demolish it to fit, so I’d go for the box and know that it’ll work.
    aqualectric
    Thanks, Chris!!
    Just to check, what’s Masterpart showing for 483257? £76 inc VAT from Connect. 🙁
    Cheers,
    Steve.
    #254240
    £62 – List is £75………..
