having a problem with this unit, it started making noises when in use, sounded very much like the motor which turns the water spraying arm,
I thought no more then sometime later month or more, the dish washer when switched on, displayed various lights flashed on and off on the operating panel, then nothing.
I have checked the mains switch which 2 poles are switching carrying mains
ok but ther are two other contacts with white wires going to then which seem to not make or break, not sure if this is correct or not, I did try poping a low value fuse across then to see if it, was a pole not switchuing the lights came on and then went off
any of your engineers there any ideas
Tonys
