Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS43C02GB/35 Classix control unit Programming
- This topic has 9 replies, 3 voices, and was last updated 9 years, 9 months ago by
martin1956.
June 13, 2016 at 9:28 am #88546
martin1956
ParticipantHi,
I have been trying to locate the setup instructions for the control unit in the above model.Can anyone help. I’m not sure that it will fix my issue but I would like to eliminate it. If it doesn’t work, I’ll need a new control unit and will need the instructions anyway
Thanks in advance
June 13, 2016 at 11:11 am #438526electrofix
ModeratorRe: Bosch SGS43C02GB/35 Classix control unit Programming
try telling us the Enr number and your problem
setup instruction normally come with new timer and are just for initial setup. one set it does not need changing
June 13, 2016 at 12:00 pm #438527martin1956
ParticipantRe: Bosch SGS43C02GB/35 Classix control unit Programming
Dave,
The issue is the tablet dispenser door not working. It has been replaced so I suspect the controller. It stopped working sometime ago, maybe before the controller was replaced under the fire recall.I just wanted to eliminate any mis programming that may have occurred before I purchase a new control unit. Not sure about the ENR number, is that from the control unit itself?
June 13, 2016 at 12:09 pm #438528Martin
The solenoid on the old dispenser could well have blown a triac on the PCB. The set up instructions you refer to are purely for the initial configuration and of no help in this instance. If a microprocessor chip has been corrupted there are no cures other than to replace the board altogether.
If the machine works otherwise it would be better to ignore the use of the dispenser and just lay a detergent tablet in the open compartment instead. Washing performance will NOT suffer.
June 13, 2016 at 1:22 pm #438529electrofix
I see the Enr number now missed it right under my nose but have you got the fd number
did a quick search here
http://www.repairaction.co.uk/bosch
I picked a random FD number and your Enr and it says it was part of the recall for fire problems
has yours been done ? if not check to see if its needed and I think they fit a new timer as part of the jobDave
June 13, 2016 at 5:09 pm #438530martin1956
Dave,
Yes the dishwasher was subject to the repair action and the timer was replaced. I’m now trying to check if the new timer was programmed correctlyThe FD number is 8309 and here is the information from the programmer if it helps
Melecs 5WK57852
EWG/0254 210511 TYPH.2
5600048705 AI 4.1.01Martin
June 13, 2016 at 5:24 pm #438531electrofix
the programming involves pushing various buttons to change programme for various models. it does not change unless someone enters the programming function. I have not got that info as it comes in the box with the new timer but may be on the net if you dig around unless anyone else can help. but I don’t think it will alter your dispenser problem. As an engineer I would have opened the timer and looked for damage on the board where the dispenser is fed from
June 14, 2016 at 1:12 pm #438532martin1956
Thanks, I did open up the controller unit, it all looks ok. Contacts are good, no signs of burn out on the PCBs etc. I’ll try searching the net further for instructions as I’m wondering whether it was indeed programmed correctly after the recall. It was quite a while ago and I cant remember whether the dispenser door problem was pre existing that fix or not. I don’t think the test done by the service engineer would have tested the dispenser door, as I recall it only took a few minutes.If anyone else does have the instructions to set up a new programmer for this model it would be very much appreciated.
June 14, 2016 at 2:02 pm #438533electrofix
when your looking for problem in the timer the resulting damage can be very small. most units use surface mounted traics the are approx 6mm by 3mm and all that will show is a small hole in the plastic
June 28, 2016 at 8:40 am #438534martin1956
Thanks Dave,
I’ll take a look with a magnifying glass but for now I’m just letting it run for 20 minutes then throwing in a tablet as it starts its main wash cycle. Not sure it is worth investing in a new programming unit. Might do though as I am very pleased with the performance of the dishwasher and most people tell me that newer units are not as goodMartin
