bosch sgs43c02gb/35 goes on and on
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch sgs43c02gb/35 goes on and on
  • #61218
    clockworkone
    this d/washers fault was not heating checked heater was ok.removed module and found dry joint on relay. resoldered leg. now machine heats ok but goes on forever and has to be stopped manually. thinking it may be gunged up.any thoughts.paul
    #345335
    Re: bosch sgs43c02gb/35 goes on and on
    clockworkone wrote:thinking it may be gunged up.any thoughts.paul
    We can’t rule that possibility out without checking it first for sure.:wink:
    If all the mechanics of the machine check out OK only then you can point your finger back at the module as being the reason. 🙁
