Bosch SGS43C02GB/35 not draining/filling
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS43C02GB/35 not draining/filling
  • #86385
    ollnixon
    The above dishwasher failed to drain the last time it was run so rather than do simple thing and get someone to have a look, I decided to have a go myself. I ended up replacing the inlet value but that hasn’t fixed the issue.
    The symptoms are:
    – Water doesn’t drain
    – If manually drained, (lifting the red switch in the photo) water is pumped out through the waste pipe
    – When turning it back on, no water comes in (hence replacing the inlet valve) and it heats and circulates the little water that was left after draining.
    If anyone has any ideas, it would be much appreciated. Thanks
    Image also available: https://dl.dropboxusercontent.com/u/15053920/IMG_20151011_150727294.jpg
    #430960
    KingGreg
    Re: Bosch SGS43C02GB/35 not draining/filling
    Hi OllNixon,
    Sounds like we have a similar issue with the same machine..
    Did you get it resolved?
    Thanks, Greg
    #430961
    ollnixon
    No, I haven’t managed to resolve it yet. I also posted the problem on another forum (http://www.diynot.com/diy/threads/bosch … st-3497698) and there are a few other comments on there but no resolution yet. I suggest you post a reply on there and see if @nijafe got any further.
    Oliver
    #430962
    The two photos appear to show the sump is full of water and that the pressure switch has activated the microswitch. So was it manually filled to achieve that?
    #430963
    ollnixon
    Yes, I filled it manually to see if it would drain.
    #430964
    ollnixon wrote:Yes, I filled it manually to see if it would drain.
    And it drained OK when you pressed the reset buttons did it?
    #430965
    ollnixon
    Yes, it did (assuming the reset button is the red switch?)
    #430966
    ollnixon wrote:Yes, it did (assuming the reset button is the red switch?)
    Nope, but at least the drain pump is OK and not the issue here. (Reset : Pressing two programme buttons together to reset the programme to zero. As shown in user manual).
    That aside your problem is that it will not fill, yes? Well it won’t unless you reset the programme so try that next.
    #430967
    ollnixon
    Hi Martin, thanks for your help.
    Having just reset, the dishwasher drained successfully. I then put it on a pre-rinse and nothing much seemed to happen; it hummed away for a bit but didn’t fill with water and start the rinse.
    #430968
    ollnixon wrote:Having just reset, the dishwasher drained successfully. I then put it on a pre-rinse and nothing much seemed to happen; it hummed away for a bit but didn’t fill with water and start the rinse.
    In that case the circuit to the fill valve or the fill valve itself is faulty (yes I realised you replaced it so the former is the most likely). Any signs of mice activity in there (droppings?) as mice love to chew wires.
    #430969
    ollnixon
    No sign of mice. Is there any way to confirm that the issue is with the circuit or do I just have to replace it and hope for the best?
    #430970
    OK so no mice damage. What else? The microswitch (that’s the one on the top not the red lever one) on the fill matrix faulty? The tap not allowing water flow to the valve? The complete pressure chamber (00482936) faulty?……I’m running out of options here….. :rolls:
