Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch SGS43C12GB/08 dishwasher overfills.
- This topic has 7 replies, 5 voices, and was last updated 18 years, 9 months ago by
aqualectric.
July 10, 2007 at 8:53 pm #28900
aqualectric
ParticipantBosch SGS43C12GB/08 Dishwasher. FD 8412.
Machine fills and starts to wash. It continues to fill and then the pump cuts in; machine is still filling. Float inside is fully raised as the water level seems quite high for this age of machine. Pulses the pump on /off, filling never stops.
OK, I’ve found what I think is a flowmeter on the inlet side of the airbox; connected inline with the blue supply hose from the valve. Is this possibly the culprit, or am I looking at the PCB?Any help please!!
Steve.
July 10, 2007 at 9:00 pm #220581Penguin45
ParticipantRe: Bosch SGS43C12GB/08 dishwasher overfills.
Flow meter, every time. Gegsy will tell you horror stories about them………. 😀
July 10, 2007 at 9:09 pm #220582gegsy
Yep, little buggers they are for failure 😥
P/no 424099Greg
July 10, 2007 at 9:20 pm #220583aqualectric
Thanks, Chris!!
But how do they function and why do they fail? Also, Greg’s horror stories…..any common faults to watch out for??Cheers,
Steve.
July 10, 2007 at 9:22 pm #220584gegsy
The wheel bearing appears to wear and then chaff thus giving duff signals back to module making it think it has turned less (not enough water entered) so fills longer till it sees the correct amount of pulses (or not) but by then its too late, overfilling has occured 😀
July 10, 2007 at 9:42 pm #220585aqualectric
Cheers, Greg!!
“Look…. that’s how it is and that’s how it works” as my instructor at BAE used to say when I were a lad. 😆Steve.
July 11, 2007 at 10:35 am #220586mowerman80
Hi guys ive got one of these d/w at the mo and its not taking enough water in. It starts to fill then pumps out fills again etc etc even does it with the door open ,no problem with the anti flood though.
July 11, 2007 at 4:37 pm #220587Redflame
Check out the prev post about these..
