Bosch SGS43C12GB/15
  • #91978
    mikeputt
    Any ideas on this Classixx Electronic it drains at the start of the cycle, fills, circ pump works, arms work and then it stops, the active, rinse aid and salt lights flash off for about 7 seconds and on for 7 seconds, I thought it might be the heater but thats not going down to earth, and there is resistance across the element so that should be ok, any ideas would be greatly appreciated
    #449927
    Re: Bosch SGS43C12GB/15
    Have a close look at the main control unit. Especially look for burnt PCB tracks.
    #449928
    mikeputt
    Thanks Martin, will check later
    #449929
    mikeputt
    Pulled out main and mini board last night, both look perfect, no burnt out tracks no dry joints and no scorch marks anywhere, any other ideas, thanks
    #449930
    I was hoping for more direct evidence that the control module was at fault, but the symptoms still point toward it being so. 😕
    #449931
    mikeputt
    Ok thanks very much for your help Martin
