Bosch SGS43CO2GB/35 no lights – dead
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS43CO2GB/35 no lights – dead
  • #46686
    micsout
    My machine stopped working with water still in the bottom and no lights on the front panel.
    I have checked the plug socket/fuse and the pump impeller in the bottom
    they appear to be o.k.
    I managed to get the top front panel off and i have got power going to the on/off switch. I think that the door interlock is working o.k. i checked it using a test lamp and my limited electrical knowledge.
    What can i test now and how?
    If anybody has any ideas what the problem is it would be much appreciated, my wife is starting to give me earache.
    #290508
    Simon46
    Re: Bosch SGS43CO2GB/35 no lights – dead
    May be module. Please do not test live. Unplug power and check for live /neutral using ohms scale on multimeter.
    S.
    #290509
    micsout
    Thanks for the tip Simon46 !
    But this is not helping me with my problem.
    Are you an expert in stating the obvious ?
    #290510
    superfix
    Doubt you’ll get much help now !
    Live testing is NOT needed, Don’t do it.
    #290511
    micsout
    If that’s the expert technical help i am going to get
    FORGET IT
    #290512
    Once again, all posters are reminded to read and understand the Forum Rules, which are posted for everybody’s safety, guidance and clarity in what the forums can offer.
    In view of the information posted so far, using a test meter to chase the wiring through the power switch and door switch into the PCB should prove continuity. If it’s there, the culprit will be the PCB. You may hit lucky and find that there is a burnt-out solder joint in the power supply, but don’t bet on it.
    Replacement PCB is p/no 491651, about £85 I think.
    Micsout, it’s not personal. If you get a shock trying to solve this, it will not come back to advice given on this forum. We also have future readers of these threads to consider.
    Good luck with it,
    Penguin45,
    Moderator.
