I’me in need of info re the wires on to the motor for the divertor valve.
There was a water leak (maybe at the salt container gasket & nut) causing a burn up of this motor and its connector block.
The wire colours are: 2 white; 1 grey; 1 white. These 4 wires were held in a plug/block connected to 3 terminals on the motor. I cannot figure for sure which goes where due to the damage.
The FD No is 8304 980377
I have looked at a number of other bosch dishwashers but none have the same coloured wires and there does’nt seem to be any common arrangement for the wires.
It’s going to be someone with access to Bosch wiring details I think or maybe someone is working on exactly the same model right now.
thanks in advance to anyone who can help.
tom
