Bosch SGS43E02GB/45 unable to load new board
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGS43E02GB/45 unable to load new board
  • #66751
    chitts
    I have just fitted new board and trying to set up found it would not load required settings. Thinking the board was at fault, ordered another, same problem!! Machine works, but settings are wrong. Any clues?
    #365110
    Re: Bosch SGS43E02GB/45 unable to load new board
    I’m not sure if you are aware but this module is one that is part of the official BOSCH RECALL and you should have advised your customer contact Bosch where they fit them FREE OF CHARGE and that is the best option still open to you, maybe? 😕
    Otherwise you are in the doo doo right now on this one for sure. Can I ask if it came with a ‘Configuration Sheet’ attached? If so, did you configure it correctly? Has a component blown the new PCB on switch on maybe?
    #365111
    nomadPaul
    You may have to programme the PCB with the facia panel off ! To code the module , you’ll need to holddown the 4 buttons starting from the right whilst then switching the appliance on. On some models , the far right button isn’t used on the panel so you can’t hold it down when coding. The only way is to do it with the facia panel left off.
    #365112
    chitts
    Bosch have carried out mod so job sorted. Thanks for your input.
