Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS43T02 GB/06 not draining. Pump maybe?
- This topic has 4 replies, 2 voices, and was last updated 15 years, 8 months ago by
toys19.
August 9, 2010 at 7:52 pm #56409
toys19
ParticipantGents,
My Bosch SGS43T02 GB/06is not draining, and at the end of the cycle leaks a little bit. I manually bailed all the water oput and watched it, same again. I wondered if it was the pump maybe? I feel sure thatin the past if you hold the start button down it will eventually start draining, but now when I do that nothing happens. So I kind of suspect the pump or connections to it, but I’m speaking from aposition of ingorance, so any help woulod be gratefullyreceived…August 9, 2010 at 9:18 pm #327285clivejameson
ParticipantRe: Bosch SGS43102 GB/06 not draining. Pump maybe?
Most likely just a blocked/fouled pump…the model number you’ve given isn’t recognised on the Bosch website but if your machine has a stainless steel tub (rather than grey plastic) then have a look in your instruction book, it will tell you about the small cover in the sump which can be removed by the one torx screw holding it in. This will expose the impellor so you can chaeck if anything is jamming it.
Just be a little careful if you poke a finger in, sometimes it’s a sharp chip of glass in there .
If you have the cover off then start the machine on any cycle for a few seconds, very often the pump will run and kick out whatever was stopping it 😉
August 10, 2010 at 6:03 am #327286toys19
ParticipantRe: Bosch SGS43T02 GB/06 not draining. Pump maybe?
Hi Clive,
I corrected the model no its actually a Bosch SGS43T02 GB/06. It has a plastic tub. I cant find the manual how do I acces the sump?Cheers
August 10, 2010 at 6:30 am #327287toys19
I think I fixed it, took the galvanised cover off the bottom, found the exit pump. It had a plastic tang stopping it from rotating to remove, so I had to break the tang is this correct? Anyway I found a big ceramic chip in the pump vanes (from a plate)& removed, and we are on an express cycle now to test. Fingers crossed and cheers for the pointer.
August 10, 2010 at 3:22 pm #327288clivejameson
Actually the tang just needed to be depressed and would lock the pump back on again after, having said that they are quite a snug fit so unlikely to ‘un-bayonet’ itself IMO
Glad you got it sorted.
