Bosch SGS43T92GB/37 Dishwasher
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGS43T92GB/37 Dishwasher
  • This topic has 5 replies, 3 voices, and was last updated 12 years ago by sdl.
  • #80079
    sdl
    I have a bosch SGS43T92GB/37 dishwasher in for repair.
    All it will do is fill and then drain. It does not go into wash mode. The “Check Water” light comes on after a delay. The inlet solenoid is working and the machine fills with water. Just after the inlet solenoid is a “Impeller Jug” which I guess tells the control that there is water entering the machine.
    Question: Do these give trouble and how can I test it?
    I don’t have any experience with dishwashers so any help will be useful.
    Regards
    Pete
    #411610
    Hollytree_Technical
    Re: Bosch SGS43T92GB/37 Dishwasher
    If you search for “impellor Jug” on here you will find that it is a very common cause of the check water light coming on – you can try checking for continuity being made and broken will putting a magnet back and forth across it or just change it anyway.
    Jem
    #411611
    sdl wrote:Question: Do these give trouble and how can I test it?
    Yes they do and don’t bother to “test it”, just replace it. (Always worth having a couple as van stock). 😀
    #411612
    sdl
    Thanks for the replies, I have ordered one.
    Pete
    #411613
    Order a couple as they fail all the time!
    #411614
    sdl
    I fitted new impeller jug and all working fine now, thanks for the posts.
    Curiosity got the better of me so I did some tests on the old and the new one before fitting it. I connected an oscilloscope across the outside two connections and then blew through the impeller, on the new one I got a nice waveform but on the old one just rubbish. I then broke the old one open and found the glass on the magnetic switch was broken, no other thing seemed wrong.
