Bosch SGS4472ZA/17 FD8403
Viewing 3 posts - 16 through 18 (of 18 total)
  • #328400
    nomadPaul
    Ollie , as Martin says , when these appliances have had ‘no heat’ probs it can throw the timings out. IIRC , these models use the length of the last wash as their starting point for the next cycle hence you may get 199 mins on the first cycle you try. The times can jump and down quite dramatically so I’d follow his advice and get the customer to run the hottest cycle all the way through ( maybe noting how long it takes ? Should be around 2/2.5 hrs ) and hopefully the times will right themselves.
    #328401
    Micky 32
    Re: Bosch SGS4472ZA/17 FD8403
    Probably not related, i went to a Siemens diswasher that had blocked pipe ( the usual one at the bottom at the front) It registered a fault.
    After cleaning i went to set it and the customer pointed out when you now set it the numbers in the display for minutes was all wrong, way higher. when i pressed the 2 buttons to reset it then went back to normal.
    #328402
    OLLIE2806
    i wish it was that bud, but i’ve held the 2 buttons to reset it numerous times. think i’m going to have to go with board.
