Bosch SGS45A02GB TOTALLY dead.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS45A02GB TOTALLY dead.
  • #95151
    Bigoffy
    I have a 6 year old Avantixx dishwasher and it hasn’t been a jot of trouble since I bought it but this morning it was showing no sign of life at all when I tried to start it.
    It is getting mains AC to the switch (both poles), the switch is working (both poles) and live is going over to the control board but that seems to be it. No lights, no noises, nothing.
    To elaborate, I can read 240VAC between chassis and the plug that takes the live from the switch into the board, but the neutral doesn’t appear to take that route.
    So live is getting to the board but possibly not neutral, is there something in the neutral which may have tripped thus preventing the controller from powering up?
    Thanks in advance everyone 🙂
    #459529
    have you opened the board and checked for damage ?
    Bigoffy
    Thanks for your input Dave, I have now opened it up and there is no sign of damage, either visually or nasally 😉
    #459531
    well its either lack of either live or neutral getting to the board or the board power supply has possibly failed
    Bigoffy
    Thanks again Dave.
    I have been doing some more digging and have identified all of the connections to the board. the 3 small brown connector goes to the mains switch and the door switch, the small brown from the door SW to the board seems to be dead, so it appears that part of the mains switch function has failed. A new switch is MUCH cheaper than a control board so I am very inclined to buy another switch and take it from there.
    Regards, Goffy.
    #459533
    in that case electrically bridge the switch to prove you are correct
    if it works check its the switch faulty and not machanical lock problem
    if just switch showing on bosch site about £12
    Bigoffy
    Hello once again 🙂
    I have linked out the failed switch contacts and am now as sure as I can be that mains is reaching the control board.
    The mains into the board is a 3 way mini edge connector with three brown wires which only go to the main switch and door switch. 1 & 3 go live on main switch made, and when the door switch is made 1 & 2 go live in addition to 1 & 3. (common neutral and 2 live?)
    But still there is no sign of life 🙁
    Is it possible the switch failure has spiked the board and killed it?
    Cheers for now, Goffy.
    #459535
    from here in it get more technical. look at the board and look for a big ish resistor that should have a resistance of around 40 to 100 ohms. find this resistor and see if its open circuit. if you find it we will take it from there
    Bigoffy
    Hi Dave,
    Resistor marked 100 ohms but open circuit 😉
    Goffy.
    #459537
    right it may be just that resistor. The resistor has a dual purpose A) it stops large current flow when you turn on B) acts as a fuse if something goes wrong
    So its either
    A) just the resistor that blew because of a faulty or arcing switch
    B it blew because the power supply chip failed ( look for a small 7 leg chip normally LNK??? ot TNY??? )
    I normally change both to be certain
    Felipe Garre
    I have the same issue. Reading the colour code was difficult as the resistor had burnt and cracked.
    Could you please confirm it is a 100 Ohm? and what wattage? 2W, 5W?
    Many thanks!
    Felipe
    #459539
    Felipe Garre
    @ electrofix
    Dave, you are the master!!! I checked in detail my “7 legged” and it’s also damaged!!
    1036 (?)
    LNK 304GN
    84939L
    I will wait for your advise on the resistor and I will also get one of the “7-legged” ones 🙂
    Thanks!
    Felipe
    #459540
    Felipe Garre
    By the way… this happened just after a huge storm… and before it happened to my fridge.
    I get 241 V on my outlets.
    May be I should get some king of surge protection?
    thanks
    #459541
    sorry for ne reply been away in Uganda till now with no internet or mobile signals
    resistor should be 3 watt fusible at least thats what i would fit
