Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › bosch sgs45c02gb/11 dishwasher
- This topic has 9 replies, 3 voices, and was last updated 11 years, 7 months ago by
suedehead1.
September 8, 2014 at 9:56 pm #82158
suedehead1
Participanthi the dishwasher seems to run ok but sticks with 1 minute to go.
its not the one with the clear tube which gets blocked. it has a thin metal plate on the base. heater ok wiring ok pcb looks ok.
any ideas welcomed.September 9, 2014 at 6:56 am #418923Martin
ParticipantRe: bosch sgs45c02gb/11 dishwasher
1 min to go indicates a ‘time out’ for whatever reason. Fill, Drain or Heating? The three most likely areas to check out.
September 10, 2014 at 6:41 am #418924suedehead1
I hate dishwashers thanks for the reply.
September 10, 2014 at 6:59 am #418925Martin
suedehead1 wrote:I hate dishwashers thanks for the reply.
But once you gain ‘the knowledge’ you will just love them and will be straining your leash to get at ’em. 😉
September 10, 2014 at 7:12 am #418926suedehead1
dont think i will get the knowledge on this one it filled emptied and heated.
does it know its filled could be flow meter, does it know its emptied or heated could be pcb.
It looks like its heading for landfill. it will take too much time trying flow meter or pcb then the dreaded phone call “its still not working”.September 10, 2014 at 7:28 am #418927Andy jones
Worth trying impellor jug before it’s binned
Sent from my iPad using Tapatalk HDSeptember 10, 2014 at 7:34 am #418928Martin
That model is in fact the easiest to fix. Simple access underneath. Both the Impellor jug and PCB are cheap (the PCB rarely fails on these anyway) I’d say the heater the most likely suspect in this case.
This may go landfill but if you get chance to check out another then they are no problem. It’s the latest plastic base models that are BIG trouble, believe me! 🙁
September 10, 2014 at 9:11 am #418929Andy jones
Agree with Martin. Had to replace heater assembly on the later model and complete base had to come off. Nightmare
September 10, 2014 at 7:22 pm #418930suedehead1
agree plastic base is a nightmare i am going to change pcb and impellor jug
September 26, 2014 at 6:54 am #418931suedehead1
changed pcb and flow meter still faulty a heater at £98 plus vat does nothing
to persuade me to persist with this piece of rubbish give me a Lamona any day. -
