Dishwasher has check water light on, and fills then empties, but never advances into the program. Water is flowing in and out of the drain hose. When I select reset it show 17 for a few moments, then 0. Reset will empty it quite quickly
Has my flow meter / impeller jug failed? (I have cleaned the filters, pump under white cover feels like a permanent magnet motor, no obvious blockages, no hoses kinked)
99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} chance that you’re correct.
If it constantly fills/drains/fills/drains from start of cycle and tap led illuminates after approx 30-45 secs then either the impellor jug has failed or its picked up some ‘grit’ from your water supply.
