select pre wash-the display shows program time,the machine fills and starts to wash.If you cancell the program the display shows 0 and it pumps out with the circulatiom motor still running.
The pump stops when the water has drained out, but the circulation motor
keeps on running and program never ends.
checked sump hose ,pressure chamber clean,tightened module connectors
board fault?.
thanks Roy.
Had this before and it was the control module -no visible damage to board
and if you get one from bsh they won’t take it back if not needed
Icannot see anything else it could be as the motor is fed by the control module -resetting should switch off the motor
also I had a couple where the module was permanently feeding the outlet
pump without the anti flood activated.
All these calls were just after thunder storms!
