bosch sgs45e02gb/45
  • #54269
    john10671
    Hi what is the quickest way of testing the heating element on this model?
    All info from start to finish would be helpful?
    Regards
    John
    #319028
    Re: bosch sgs45e02gb/45
    Lid and r/h side panel off, plug out, identify white box under tub. Split circuit, meter across terminals. Somewhere between 20 and 30 ohms is acceptable.
    Then remove the l/h side panel and clean out the water level chamber and transfer pipe, which will then allow enough water to enter the machine to operate the pressure switch on the end of the heater box and allow the heater to operate.
    john10671
    Thanks chris.
    Is there a diagnostics you can do on this model and if so how do you do it ?
    John
    #319030
    There is no test mode as far as I’m aware. If the heater is showing an acceptable reading, a no/poor heat problem on these machines is always an underfilling issue.
    john10671
    Cheers Chris you were right it was the hose and chamber blocked solid unblocked and cleaned out chamber and hey presto
    Thanks again
    John
