Bosch SGS45E02GB/45 wont start program
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS45E02GB/45 wont start program
  • #89720
    ChrisRatters
    Hi Dishwasher initial fault would not drain cleared blockage , then would not fill replaced water inlet solenoid. When turned on program selected it drains then nothing does not start. I have filled with water it will drain if program cleared no water coming in via new water switch? I did have an issue with door switch which I had to reposition catch after checking pump with door open. Could this be the problem?
    #442299
    ChrisRatters
    Re: Bosch SGS45E02GB/45 wont start program
    Back again Mem Sahib fed up kitchen covered in bits! I have bridged door switch still nothing program wont start and no water flow in so that idea out?
    It will drain if I fill it with water via kettle etc and cancel program or move red lever on left hand side. Is there a way to check any thing else? Thanks Chris
    #442300
    Severe case if barking up the wrong tree before waiting for an answer first. 😉
    Most likely the Impellor Jug (00424099) needs replacing.
    #442301
    ChrisRatters
    Job done working OK judicious removal and refitting of all connector blocks seems to have sorted it. Is there a fault code for impellor jug other comments on web advise if its defective the machine fills and drains repeatedly?
    Thanks for all those that looked and advice
