Bosch SGS45E08GB/45 no heat
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS45E08GB/45 no heat
  • #89946
    stealthcamper
    Good afternoon, ive got a bosch Exxell dishwasher thats not heating up, ive tried to follow some of the previous posts and carry out some of the tests but not found anything conclusive. Ive cleaned all the pipes, checked its filling up to correct level, even measured the element resistance,23ohms, its just not getting hot. Could this still be the element?
    Many thanks Stu
    #443100
    Re: Bosch SGS45E08GB/45 no heat
    Most common reason: Solder joint on PCB (aka Control Unit) has burnt out and the pin needs cleaning and resoldering to repair.
    #443101
    stealthcamper
    can someone point in right direction for pcb? Ive got the heater out tested the thermistor too and alls ok with that end.
    #443102
    stealthcamper wrote:can someone point in right direction for pcb?
    “Someone?” Didn’t I just respond to your plea….deary me. :rolls:
    The PCB is the main control unit in the door ( the thing with the buttons you press) 😉
    #443103
    stealthcamper
    found it:) pcb burnt under the relay
    thanks Martin :tup:
    #443104
    stealthcamper
    relay replaced, washer now runs and gets hot but never stops now lol
    #443105
    stealthcamper wrote:relay replaced, washer now runs and gets hot but never stops now lol
    Lol eh? When you’ve stopped laughing and if you need further guidance, you know where to come TTFN 😉
    #443106
    stealthcamper
    All good ran a few cycles and working fine. thanks to Martin and the site for help and guidence, purchased the relay from RSonline less than £2 fix 🙂
