Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch SGS45E08GB Dishwasher not finishing or restarting
- This topic has 7 replies, 3 voices, and was last updated 16 years, 5 months ago by
Peanut33.
October 17, 2009 at 1:06 pm #49392
Peanut33
ParticipantHi, my dishwasher fails to finish it’s cycle and stop, it will not even spray any water when in cycle. Pumps ok though.
October 17, 2009 at 1:37 pm #299753Penguin45
ParticipantRe: Bosch SGS45E08GB Dishwasher not finishing or restarting
Cycle will not complete if no heat; there is a pressure switch in the heater box which needs circulation to allow the heater to activate. Therefore you need to look at the motor – it may be jammed or the start/run capacitor may have failed.
Remove r/h side panel for access – power off first.
October 17, 2009 at 1:54 pm #299754Peanut33
Are these visible after removing the panel?
Cheers
October 17, 2009 at 1:58 pm #299755Penguin45
Correct.
P45.
October 17, 2009 at 2:01 pm #299756Peanut33
ok panel is off and I can see many parts, what am I looking for and what should I be doing?
Matt
October 17, 2009 at 7:26 pm #299757Penguin45
Circulation motor is the square metal casing with the fan in the end. If turned manually, it should feel “heavy” but smooth running, in which case the capacitor is the most likely culprit. If it won’t move, you have a bigger problem.
October 18, 2009 at 2:21 am #299758gandh1
Peanut how long have you had the d/w, and how hard have you used it because its not an “old” model. I only ask out of interest because ive been doing a quite a few circulation-motor impeller replacements lately on a batch of 4-8 year old boschs and neffs :S
i dont know whats been happening lately but no4 this month is on its way to the w/shop next week!!! had 2 last month as wellOctober 21, 2009 at 10:26 pm #299759Peanut33
Had it about 3-4 years.
Thanks P45 will check abain and try turning manually, will let you know.
thanks
