Bosch SGS45E62GB/52. FD 8505000597
Home Forums Public Support Forums General Enquiries And Questions Bosch SGS45E62GB/52. FD 8505000597
  • #97399
    Alilou
    Morning All
    i have a dishwasher displaying “check water “start blinking after drying cycle is finished.
    checked impeller and matrix on the side everything is cleared?
    can you please help?
    kind Regards
    Alilou
    #467474
    cant think why it would only start doing this at the end of the programme
    this unit was built 2005 so at 15 years old some components wont work as well, so with the age taken into account the 2 components that normally cause this fault are
    1 water valve. the amount of water entering the machine per second may be reduced by on old valve. the machine counts the water in and is expecting a flow rate of ?? liters per second ( dont know the amount) if it falls below this the light comes on
    2 impellor jug. This device actually counts the water in and had a few of these fail. they count the water in in pulses but the switch degrades with age and skips more and more till the computer thinks there is not enough water going in
    as said these fault normally only appear as the machine is filling so what you are saying does not make sense
    Alilou
    Hi Dave
    Thanks very much indeed for your prompt reply.
    Just to give you more clues. “Water check” stay on until the end of cycle!!
    monitored the matrix on two occasions and it’s not full of water? Is this related to the problem?
    Many thanks for your massive help!
    Regards
    Fred
    #467476
    when during the cycle does this light come on ?
    or does it vary
    it should only come on while its filling but may then remain on as a warning if the unit get enough water
    Alilou
    After the “Drying”light goes off.
    ”check water”light comes on and stays on!!!!
    i am assuming towards end of cycle!!-
    Also noticed . Inside machine over mouldy!!
    Regards
    Fred
    #467478
    it is heating isn’t it ?
    Alilou
    Run a quick cycle @45
    dishes were cold!!
    should I try an intensive @70 to compare
    or it’s irrelevant!!
    Regards
    Fred
    #467480
    sounds like your heater is not working. Thats where your mould is coming from
    on these early models first place to check is the timer. there is a relay that controls the heater and bad solder joints are common
    Alilou
    Thank you very much Dave
    i will check it out.
    Regards
    Fred
    #467482
    Alilou
    Afternoon Dave
    I hope you are keeping well.
    where can I please find the timer?
    OR
    Do I need to replace the followings:
    The water heating element
    Turbidity sensor
    NTC sensor
    Please advise?
    Regards
    Fred
    #467483
    timer is the electronic panel under the buttons you use to set the programme
    remove it
    open it up carefully and inspect the panel solder side and look for bad joints
    Alilou
    Thank you Dave
    Much appreciated
    Fred
