I put the dishwasher on a full cycle which displayed 130 mins, after approx. 95 mins the cycle decided to stop. I have reset the program but still nothing happens when switched back on. Is there anything I can do ?
The fuse hasn’t blown as there is a lit display. I tried to reset as per the handbook (holding down 2 of the program settings for 3 seconds) The display clears and is reset to ‘0’. Nothing happens after this point. No water has been drained.
I then switched the washer off then back on selected a program and waited. … still nothing..
In that case the pump has got blocked. Remove the filter and undo the Torz headed screw (T20 size) holding the pump cover in place (see your user booklet) Lift the cover clear and check for anything stopping the impellor blades from turning (be careful in case of broken glass!)
