Bosch Sgs45EO2GB/45 d/w
  • #41567
    reaper
    Machine operating with not enough water-the level doesnt even come up to the drain screen.Intermittent filling 2 seconds then off repeated about 6 times.The machine still goes through the programme but without enough water to clean.
    #270623
    smartin
    Re: Bosch Sgs45EO2GB/45 d/w
    check the hose from fill chamber to sump its prone to sludging up
    #270624
    Pressure chamber and transfer hose to sump full of crud. Strip and clean.
    aqualectric
    Almost certainly the water metering matrix and sump feed pipe under the left side panel. The sump pipe will probably be clogged with gunge and this slows the water into the machine. Backing up of this water will cause the on / off filling situation. Remove all the parts of the float chamber and sump pipe, clean out and refit.
    HTH,
    Steve.
    #270626
    Evenin’ Smarti, Aqua. :waving:
    :p45:
    #270627
    smartin
    makes a change for me to beat my flightless feathered friend for a change 😆
    #270628
    aqualectric
    Penguin45 wrote:Evenin’ Smarti, Aqua. :waving:
    :p45:
    Hi, Chris!
    Question is, what the hell are we doing on here when I’m a Celebrity is on? :snig:
    Steve.
