Bosch SGS45EO2GB/45 fault.
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Bosch SGS45EO2GB/45 fault.
Viewing 15 posts - 1 through 15 (of 17 total)
  • #32698
    stav
    Hello,
    I have the above mentioned dishwasher that has developed a fault. I’m no expert but am quite technically minded and don’t mind repairing stuff.
    The problem is the dishwasher starts filling, gets full and the float switch engages,it them begins to drain (cos of the switch) it drains for 2 seconds then starts to fill again. It fills until the float switch is activated, then begins to drain and so on and so on, it does this forever and a day and never actually starts to clean.
    I’ve had the thing apart and cleaned all the pipes and tubes on the left hand side of the machine, including the float switch. I guess it’s the electronic programmer but want someones professional opinion before I cough up the £75 for a new one.
    What do you guys think?
    Thanks in advance.
    #236067
    Re: Bosch SGS45EO2GB/45 fault.
    It’s a classic PCB failure on these particular machines. Replacement board has modified software.
    gegsy
    I would also consider the flowmeter/impeller jug p/no 424099
    These are prone to give problems like you are getting.
    Module and/or impeller jug are available from spares@ukwhitegoods.co.uk
    stav
    Well, I tried the module! £85 later, no joy!! it still won’t start the programme. It fills but won’t progress on to actually washing.
    Do I try the impaller jug or cut my losses and buy a new one?
    Help, please help.
    #236070
    gegsy
    You’ve come this far for the sake of an impeller jug it has to be a worth a shot.
    Obviously its your decision 😉
    stav
    What does the impeller jug do and where does it go?
    #236072
    superfix
    It’s an in line flow meter and as such sits in line of the water supply.
    #236073
    stav
    if it’s only £11 I guess it’s worth a go.
    #236074
    superfix
    I’m 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure that will cure your fault 😉
    #236075
    stav
    Woo Hoo!!
    I took the impaler jug off, gave it a blow (both directions) to get it moving and clicking and HEY PRESTO!! my dishwasher is working fine!!
    Obviously if it goes again i’ll just replace it (the impaller i mean)
    Can’t believe i’ve had to waste £16 on ordering and then sending back a module when all along it was an £11 piece of plastic.
    Thanks guys, if it was up to the missus I would be £250 out of pocket with a shiney new dishawasher in the kitchen.
    I’m off to buy a new guitar to celebrate, well I have got a spare “250 now:0)
    #236076
    ringley
    Hi everyone. I’ve got an SGS43T12 and it’s doing exactly the same thing. I’d also like to fix it myself, but am not completely sure where to locate the impeller jug. Do I access it from the inside of the machine or from the rear? Can anyone advise please? Many thanks!
    #236077
    Remove plug and left hand side panel for awkward access.
    ringley
    Penguin45 wrote:Remove plug and left hand side panel for awkward access.
    Thanks, and what am I looking for? Anyone got a picture or a diagram? Thanks!
    #236079
    ringley wrote:Thanks, and what am I looking for? Anyone got a picture or a diagram? Thanks!
    #236080
    ringley
    Thanks! Will have a go tomorrow.
