Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch SGS45EOGB/56 d/washer
- This topic has 7 replies, 4 voices, and was last updated 19 years, 6 months ago by
effzedarr.
September 13, 2006 at 6:28 pm #20837
effzedarr
ParticipantHi guys, got me puzzled this one. Similar to the Hotpoint m/c under the skin, put on pre-wash, drain pump starts, fills for approx 1 min,wash motor kicks in ,but all the time drain pump is going ,therefore not enough water to wash with! 😥 Checked float switch,a-ok,pump no short on it, even checked fill valve. No sign of a leak in the base either.A’m I missing summat ❓ m/c just a few weeks out of warranty 🙁
cheers guys Chris 8)September 13, 2006 at 6:59 pm #188518Penguin45
ParticipantRe: Bosch SGS45EOGB/56 d/washer
Clean out the hose from the matrix to the sump – water will be backing up and operating the flood protection.
September 14, 2006 at 2:33 pm #188519effzedarr
Thanx for the reply Chris,but I did that, all ok , looks as though the water just runs in & goes straight out again 😕 I have watched it with the lhs panel off, the float chamber stays dry! When its filling if i lift the rod up from the overflow float it cuts out the fill progress which I would think is correct, let go & it carries on ok till time out. Then it carries on pumoing & trying to wash!
regards Chris.. 8)September 14, 2006 at 7:18 pm #188520superfix
You need a new module on that one.
Had a few now that fill and empty at same time, pcb has cured it every time.
September 14, 2006 at 7:25 pm #188521gegsy
You may want to check that model number 😉 so we can get a part number for you for module.Greg
September 15, 2006 at 9:02 am #188522effzedarr
Thanx for that chaps, as for the model # it was the one on the inside of the door,very poorly stamped into the metal! I’ll see what the customer wants to do , any idea of an approx price of the pcb?
once again many thanx. Chris.. 8)September 15, 2006 at 9:11 am #188523gegsy
Please look again at the model as it has a digit missing ie- SGS45E0?GB/56.
Then we can move on with price for module. 😀Greg
September 20, 2006 at 6:15 pm #188524effzedarr
Thanx Gegsy, customer on hols or done a runner 😆 ,will get back to you as soon as poss. cheers Chris.. 8)
