Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Bosch sgs46e02/gb/75
- This topic has 9 replies, 3 voices, and was last updated 5 years ago by
felixius.
March 13, 2021 at 8:18 pm #99283
felixius
ParticipantHi Guys,
I have a Bosch dishwasher, sgs46e02/gb/75 and keep having the check water light come on.
I’ve replaced the circulating pump & the drain pump but keep getting the error.
Any idea on what to try next?
Main circuit board perhaps?
Thanks.
Felix
March 13, 2021 at 9:16 pm #475738electrofix
Moderatoris the check water light on or flashing as it means different things
is it filling at all ?
if not have you checked the fill valve ?
March 13, 2021 at 11:54 pm #475739andyjawa
ParticipantTrue, could be the inlet valve. Usually it`s the impeller jug that fails part number 00424099 about 22 quid ( rear of d/washer l/h/side corner is where the blighter is located, round white thing with 2 nozzles and 2 or 3(? from memory) plugconnector wires going to it ). Symptom is set on any programme, machine makes pump out noise then begins to fill. Can fill for, say 10 secs or can fill to what looks like the right level BUT the wash motor does not start up so gives the impression the wash motor is toast when it isn`t. The impeller jug is a water flow over time impulse counter that tells the pcboard when to start the wash motor up ( in other words it electronically takes the place of a electromechanical pressure switch which actually seldom go wrong – though it takes the likes of Bosch to come up with something that does commonly go wrong! ) the problem is they never look as though they have failed in any shape or form but they have. Do not think too much over this just change the impeller jug and it should cure your fault. ( of course as other pointers it could be the microproccessor but that would be highly unlikely or indeed the emergency red float o/flow is blocked up or its semi transparent hose to the sump which is fairly common on an old machine- sgs series is an old machine! ).
March 14, 2021 at 7:50 am #475740felixius
ParticipantHi All,
So the light is on constantly, I’ve tried re setting but no joy.
It seems to fill & pump water out when i press the reset button.
Perhaps the inlet or impeller jug (flow meter) is the issue. Though i’m not sure it has one, i’ll take a look
The red float mechanism all seems fine & hoses are all free flowing.
Cheers!
March 14, 2021 at 11:52 am #475741electrofix
Moderatorif the water flows in and then aborts and pumps out with the light on then change impellor jug as Andyjawa pointed out
done lots of them very common failure
ir check leads from impellor jug had one where mice ate the cables
March 14, 2021 at 12:29 pm #475742felixius
ParticipantHi Dave,
It comes on pretty much straight away in the cycle.
When I reset the washer it does empty the machine though.
I’ve ordered one of the Impellor Jug flow meters.
Thanks.
March 14, 2021 at 12:53 pm #475743electrofix
Moderatorif you watch the left hand side once the cover is off you should see water coming in, then it should abort
if no water comes in at all then you may have a faulty valve. the impellor jug detects water, if no water enters it cant detect anything
March 14, 2021 at 1:15 pm #475744felixius
ParticipantHi Dave,
It’s definitely getting water in, and out…. on a rinse cycle it lets water in for a bit, then the light comes on….
Still the Impellor jug?
Thanks.
March 14, 2021 at 1:25 pm #475745electrofix
Moderatorvery likely impellor jug
in order
1 impellor jug
2 cable from impellor jug to programmer
3 main board, programmerDave
March 14, 2021 at 1:34 pm #475746felixius
ParticipantThanks Dave,
Fingers crossed that sorts it!
Will let you know in a few days!
