Got this machine in workshop. Customer said it just stopped mid cycle. Found problem to be burnt out neut on mains filter. Fitted new one and put machine on test.
Now machine fills to level then inlet valve and display (LED) start to pulse at 2 sec intervals. The LEDs flashing on and off as the valve energises. It seems to be at the point when wash pump would kick in.
Bosch experts your help required. We did take off the front panel just to check supply voltage to module.
Geoff
