Bosch SGS46E02GB/75 dishwasher check water
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch SGS46E02GB/75 dishwasher check water
  • #81000
    allan
    Hi hoping someone can help me with this as I don’t have a lot to do with dishwashers, this bosch dishwasher had the check water light on, pump kept running even if door was opened, there was no water in the base,I replaced the jug impeller and all has been ok for about a week, customer phoned to say it’s doing the same thing again! Any ideas where to go next?
    Thanks Allan
    #415049
    Hollytree_Technical
    Re: Bosch SGS46E02GB/75 dishwasher check water
    Check the pressure chamber in the left hand side, these gunge up which causes the water entering the machine to back up and activate the anti flood / overfill switch which can sometimes get jammed in the activated position.
    Jem
    #415050
    allan
    Is that to the right side of the water matrix? Thanks
    #415051
    Hollytree_Technical
    Yes, it is front left of the machine, you will see a red rod coming up from the base, this is from the anti flood float and the switch that it activates is also the overfill switch.
    Jem
    #415052
    allan
    Thanks will check that out when I go later today, Allan
