hi guys , i fitted a new circ. pump to sump seal to this m/c , now it wont pump out the water after the cycle , it will reset fine during the cycle and pump out but not when finished , also the 3 led’s are flashing any info on these cheers
Must likely a connector has come adrift, maybe from the heater box or wherever? The machine is indicating a time-out error so I’d check and double check all connections, including module. 😉
cheers martin will do, also the drain hose is fed directly into the sink p- trap which is below the level of the actual waste pipework after the p-trap , if you get me their is a good bit of water to push out into the waste pipe before gravity takes over could the pump be under pressure trying to evacuate too much water ?
