Just been to this one , it fills with plenty of pressure but the check water light comes on after about 1 min. Changed the “measuring jug” but still the same??!!! Anyone have any ideas??!! 😕
Applianceman2010 wrote:Do you have any other ideas on what would be causing this martin?
On the assumption the impellor jug HAS been installed correctly…..the ‘Check water’ LED can come if the pump is blocked or restricted OR if the water inlet matrix/pressure chamber is gunged up OR if the base is flooded. 😉
